VOXL ESC Mini 4-in-1 with Built-in Power Module
$229.99
Current Hardware Lifecycle
Software Lifecycle
↪ VOXL SDK 0.7 and Greater (Release Notes)
High Performance 4-in-1 Electronic Speed Controller
Communicate reliably with low-latency digital UART from your flight controller to your 4-in-1 ESC.
Make sure to select the correct version based on which VOXL 2 you plan to use:
- The 3.8V version powers VOXL 2 Mini directly.
- The 5V version powers VOXL 2 directly.
The VOXL ESC is assembled in the USA and works directly with PX4, ArduPilot and VOXL 2.
This Mini ESC is targeted for aerial vehicles under 750g. For vehicles up to 1500g, please use the VOXL 4-in-1 ESC.
These closed-loop RPM control ESCs require tuning the ESC and propeller combination. Tuning guide: https://gitlab.com/
| MPN | Description | Components Included in Kit |
| MDK-M0129-63-01 | Dev Kit, VOXL ESC Mini V2, 3.8V, 6S, w/ cables |
M0129 ESC and cables to connect with VOXL 2 Mini (3.8V) |
| MDK-M0129-65-01 | Dev Kit, VOXL ESC Mini V2, 5V, 6S, w/ cables | M0129 ESC and cables to connect with VOXL 2 (5V) |
| Item |
Value |
ECCN |
EAR99 |
| Harmonized Tariff Schedule (HTS) Code |
8542.31 |
| Country of Origin | USA |
| Radio Frequencies Used | None |
| RoHS Compliant | Yes |
