VOXL Flight - PX4 Autonomy Computer and Flight Controller in one!
VOXL® Flight Enables Smaller, Smarter, and Safer Autonomous Drones
Due to shortages of the STM32F7, we are limiting sales of VOXL Flight to existing VOXL Flight Customers. Please reach out here to purchase offline. As a replacement, we recommend VOXL 2 or VOXL paired with Flight Core, which has been upgraded to the more available STM32H7.
VOXL Flight combines VOXL® and Flight Core into one package. This is the first open computing platform designed specifically for drones (sUAS) to combine the power and sophistication of Snapdragon with the flexibility and ease of use of a PX4 flight controller in a single PCB. VOXL Flight is 100% software compatible with VOXL and Flight Core, but in a single PCB to reduce cabling, cost and increase reliability.
Fly safer with VOXL Flight. VOXL supports obstacle avoidance and GPS-denied (indoor) navigation fused with a PX4 flight controller on a single PCB.
VOXL 2 is built on the Qualcomm QRB5165 chipset and offers 4 times the computing power of VOXL! Check out the latest at: https://modalai.com/voxl-2
Ready to Use Drone Development Tools
You can purchase VOXL Flight in a ready to fly drone, VOXL m500, or in a ready to mount enclosure, Flight Deck.
VOXL Flight Contains the Most Popular Drone Developer Tools
The VOXL Flight advances the Snapdragon Flight and Qualcomm Flight Pro architectures to provide great support for:
- PX4 Avoidance and Navigation
- ROS / ROS2 / MAVROS / MAVSDK
- Open source Linux kernel, cross-compilers, PX4, ROS, OpenCV
- Docker build environment for CPU, GPU (OpenCL) and DSP (Hexagon SDK) heterogeneous computer vision and deep learning processing.
- Run Docker on VOXL target for improved portability and maintenance.
- Add cellular LTE connectivity for beyond visual line of sight (add-on).
- Snapdragon 821: Quad-core up to 2.15GHz, GPU, 2xDSP, Linux
- 216MHz, 32-bit ARM STM32F765II, PX4
- Video support: 3x MIPI image sensors, UVC
- Machine vision support: time synchronized IMU and image sensors
- Additional I/O: WiFi, SPI, I2C, UART, GPIO
- Light weight, powerful, SWAP-optimized computing:
- Weight 24g
- Power Adapter weight 13g
- Image Sensors (6g)
- Power consumption 3-10W
MPN | Description | Components Included in Kit |
MDK-M0019-2-00 | Board Only Kit |
MCCA-M0019-2-T CCA, VOXL-Flight, Tested M10000020 Label, 2x.625 ESD CAUTION Warning Sticker, yellow MPKG-00001 ESD Bag, 3"x5"x3", Zip Lock AntiStatic Bags |
MDK-M0019-2-01 | VOXL-Flight Dev Kit, R1 |
MCCA-M0019-2-T CCA, VOXL-Flight, Tested MDK-M0022-1-01 Flight Core PWM Breakout Kit
MDK-M0041-1-01 VOXL Power Module v3 RevB Kit (VOXL, VOXL-Flight)
MKIT-00021-2 VOXL-Flight Interface Kit MKIT-00046-2 Product Marketing Inserts Kit, General MRF-M0006-1 VOXL Wi-Fi Antenna Kit |
HS Code: 8542.31.3000
Please see our handling instructions for best practices on handling your device.
