Home / Collections / All Products / Starling 2 Max GPS-denied Development Drone
$3,199.99
Selected sku: MRB-D0012-4-V4-C28-M36-T8-K0
Hardware Lifecycle
Note: There are performance issues with GPS on the current iteration of this design, an updated GPS is in development.
Software Lifecycle
↪ VOXL SDK 1.3 and Greater (Release Notes)
Starling 2 Max
Starling 2 Max is a VOXL 2-powered, NDAA-compliant development drone built for computer vision-based, long-range dead reckoning with a 500 g payload capacity. Powered by VOXL 2, our Blue UAS Framework autopilot, and supercharged by the VOXL SDK, Starling 2 Max flies for approximately 55 minutes and is our flagship development platform for both indoor and outdoor flight. Browse the rest of ModalAI’s development drones.
GNSS Performance Notice
Please review this notice before purchase.
On the current revision of Starling 2 Max, GNSS performance does not yet meet our target specification. Customers should expect longer time to first fix and reduced position accuracy in GPS-aided outdoor flight modes compared with our other airframes. An updated GNSS design is in active development, and any change will be published as a Product Change Notification.
This affects satellite-aided navigation only. Starling 2 Max is built around VOXL 2 and its multi-camera Visual Inertial Odometry, so GPS-denied navigation, SLAM and visual obstacle avoidance are the platform’s primary means of position estimation and are unaffected. Long-range dead reckoning on Starling 2 Max is computer-vision based by design.
If your application depends on precise GNSS, please contact us before ordering so we can advise on current status and expected performance for your use case. Our EMI mitigation guide for GNSS documents the integration practices we apply and recommend.
Component Specification
Autopilot VOXL 2 (Qualcomm QRB5165: 8 cores up to 3.091 GHz, 8 GB LPDDR5, 15 TOPS AI)
Image Sensors C28: Dual IMX412 (12MP), Dual AR0144 (1MP tracking)
C29: Dual IMX412, Dual AR0144, plus ToF
Take-off Weight 566 g
Payload Capacity 500 g — affects flight time; total take-off weight ~930 g
Flight Time ~55 minutes with Amprius cells (~40 minutes with Li-Ion)
Max Speed 15 m/s cruise, 20 m/s dash
Wind Tolerance Gusts to 15 m/s
Service Ceiling 4,000 m MSL
Motors 2203.5, 1500 kv
Propellers 180 mm tri-blade
Frame 3 mm carbon fiber
ESC ModalAI 4-in-1 Mini ESC (power module integrated)
GPS u-blox M10
R/C Receiver 915 MHz ELRS
Datalink Wi-Fi: Alfa Networks AWUS036EACS (FCC ID 2AB878811)
Battery Sony VTC6 3000 mAh 2S, or any 2S 18650 Li-Ion pack with XT30
Two 2S packs required, wired in series for 4S — max voltage 16.8 V
Dimensions Diagonal 512 mm (prop to prop)
Width 450 mm prop to prop / 260 mm motor to motor
Length 380 mm prop to prop / 190 mm motor to motor
Height 120 mm
  • Visual Inertial Odometry for navigation in GPS-denied environments
  • TFLite neural networks for object classification, detection and other models
  • Open-source software: OpenCV, ROS 2, Docker, integrated PX4 flight controller
  • Full VOXL SDK
Built-in Connectivity Options
  • IP datalink: Wi-Fi, Microhard, 4G LTE, 5G
  • R/C: ExpressLRS (915 MHz)
User Guide (Hardware Overview)
Hardware Quickstart
VOXL SDK Documentation
Product Brief (PDF)
Starling 2 Max is configured by SKU. Choose a camera, R/C, modem and kit configuration below.
Camera Configurations
Camera Config High-resolution Tracking ToF Thermal
C28 Dual 12MP RGB Dual 1MP Tracking No No
C29 Dual 12MP RGB Dual 1MP Tracking Yes No
Future Capability — No ETA Dual 12MP RGB Dual 1MP Tracking No FLIR Lepton
R/C Configurations
R/C Config Receiver Transmitter (if applicable) Frequency
-T8 ModalAI M0184 ELRS RX iFlight Commando 8 915 MHz
Modem Configurations
Modem Config Description
-M36 Wi-Fi
-M3 Microhard carrier (no modem)
-M11 Microhard pMDDL2450
-M20 4G LTE (North America)
-M24 5G
Every configuration ships with the -T8 R/C option. The Wi-Fi and Microhard builds are available to order above; for 4G LTE or 5G, contact us.
Kit Configurations
Kit Config Description
-K0 Drone only
-K1 Drone and battery pack
-K2 Drone with battery pack and controller
-K3 Drone with case, battery pack, wall power supply and controller
  • LiPo charger — we recommend the ISDT Q6 Retro charger/discharger
  • Additional 2S 18650 battery packs (two required per flight, wired in series)
  • Ground control station laptop or tablet running QGroundControl
VOXL ESC Mini (M0129) ✅ installed as the flight ESC
ModalAI M0184 ELRS receiver ✅ -T8 configurations
Microhard pMDDL2450 add-on ✅ -M11 configurations
4G LTE / 5G modem add-ons ✅ -M20 / -M24 configurations
M0161 / M0166 image sensor modules ✅ factory-installed per camera config
Starling 2 replacement parts ❌ use Starling 2 Max replacement parts — frame, motors and skids differ
Third-party 2S 18650 packs with XT30 ✅ two required, series-wired
Harmonized Tariff Schedule (HTS) Code 8806.22.0000
Radio Frequencies Used Wi-Fi: 2.4 GHz / 5 GHz
pMDDL2450: 2.4 GHz
4G & 5G: worldwide cellular frequencies
R/C: 915 MHz
Technical specifications
  • Autonomy
  • Perception
    • Dual AR0144 1MP fisheye CV image sensor for visual inertial odometry (VIO)
    • Dual IMX412 12MP color image sensor for streaming, image capture & video recording
    • FLIR Lepton for thermal tracking (optional)
  • Robust NDAA-Compliant Design
    • 500g take-off weight
    • 322mm diagonal SWaP-optimized carbon fiber airframe
    • 180mm folding propellers
    • 55+ minutes of flight time
    • 500g of additional payload capacity
Compare VOXL Drones
Starling 2
Price: from $2,949.99
Takeoff Weight: 280g
Flight Time: >40 minutes
Compute: QRB5165
Flight Controller: PX4
Connectivity: WiFi, ELRS
Starling 2 Max
Price: from $2,999.99
Takeoff Weight: 500g
Flight Time: >55 minutes
Compute: QRB5165
Connectivity: WiFi, Microhard, 5G, ELRS
