Video
Enhance your home page with a video that relates to your process, products, or story.
VOXL® 2
$1,399.99
Selected sku: MDK-M0154-1-00
Expected to ship within 30 business days from San Diego, CA
↪ VOXL SDK 0.7 and Greater (Release Notes)
↪ M0054-1 and M0154-1 are functionally equivalent, M0154-1 refreshes some non-logic EOL components on M0054-1.
↪ M0054-2 and M0154-2 have identical performance characteristics and capabilities to M0054-1 and M0154-1, except the -2 assemblies only support up to 4 cameras concurrently.
VOXL 2 is a Blue UAS Framework AI companion computer and flight controller in one 16-gram board — the edge compute and autopilot for an autonomous drone or ground robot in a single part. Powered by the Qualcomm QRB5165, it is the smallest single-board AI autopilot we build: eight cores up to 3.091 GHz, 8 GB LPDDR5, 15 TOPS of on-board AI, a PX4 or ArduPilot flight controller running on the sensors DSP, and 5G connectivity through add-on modems.
VOXL 2 infographic: Qualcomm QRB5165 with 8 cores up to 3.091 GHz, 15 TOPS on-board AI, 8 GB LPDDR5 and 128 GB flash, PX4 or ArduPilot on a dedicated sensors DSP, 6 MIPI image sensor inputs, 8K30 video encoding, add-on connector for 4G/LTE, 5G, Wi-Fi and Microhard radios, 16 g; NDAA Section 848 compliant, assembled in the USA, Blue UAS Framework 2.0 founding autopilot; VOXL SDK runs VIO, SLAM, obstacle avoidance and object detection on board
VOXL 2 is NDAA '20 Section 848 compliant and designed and assembled in the USA. It is supported by a large ecosystem of pre-integrated image sensor modules, modems and expansion boards, and by the VOXL SDK for GPS-denied navigation, visual inertial odometry (VIO), SLAM, obstacle avoidance and object recognition.
Built to Adapt
Because VOXL 2 carries a high-performance computer, a drone built on it is not frozen the day it ships: new AI models, sensors, autonomy behaviors and countermeasures can be deployed as software. We call this software maneuverability. Software maneuverability is the ability to change what a drone can do, as fast as the threat changes, through software.
The VOXL SDK is available in source code form at code.modalai.com, so you can make those changes yourself rather than wait on a vendor roadmap. More than 1,000 partners have built on VOXL, which is why we call it an open foundation for America’s drones.
For how VOXL 2 compares with other options, see Top 5 Companion Computers for UAVs.
CPU Qualcomm QRB5165 — 8 cores up to 3.091 GHz
Memory 8 GB LPDDR5 / 128 GB Flash
GPU Adreno 650, 1024 ALU
NPU 15 TOPS
Operating System Ubuntu 18.04, Linux kernel v4.19
Flight Controller Embedded — PX4 or ArduPilot on the sensors DSP
Integrated Sensors 2x TDK ICM-42688-P IMU, 1x ICP-10100 barometer
Image Sensors 6 concurrent MIPI — 2x stereo pair plus 1x tracking
Video Encoding 8K30 H.264 / H.265, 64 MP still images
Add-on Connectivity Wi-Fi, 5G, 4G/LTE, Microhard
Thermal Cameras FLIR Boson (USB, MIPI), FLIR Lepton (USB, SPI)
Power Consumption 0.1 - 7 W
Dimensions 70 mm x 36 mm
Weight 16 g
Compliance NDAA '20 Section 848 compliant, assembled in the USA
  • PX4, ArduPilot, ROS 1 and ROS 2, Debian 9 (stretch), OpenCV 4.4, MAVROS, MAVSDK
  • VOXL SDK: GPS-denied navigation, SLAM, visual obstacle avoidance, object recognition
  • QGroundControl and ATAK support
  • Open-source Linux kernel and cross-compilers
  • Docker build environment for CPU, GPU (OpenCL) and DSP (Hexagon SDK) heterogeneous computer vision and deep learning
User Guide
Hardware Quickstart
Feature Matrix · Connectors · Mechanical Drawings · Camera Configs
Product Brief + System Architecture (PDF)
Please see our handling instructions for best practices on handling your device.
MDK-M0154-1-00 — VOXL 2 Dev Kit, Board Only
MCCA-M0154-1-T QTY 1 CCA, VOXL 2, Tested
MDK-M0154-1-01 — VOXL 2 Dev Kit, No Image Sensors
MDK-M0041-1-01 QTY 1 VOXL Power Module v3 RevB Kit
MPS-00005-1 QTY 1 Power Supply, 12V 3A, XT60
  • Image sensor modules (sold separately — see image sensors)
  • Modem add-on for Wi-Fi, LTE, 5G or Microhard connectivity (see modems)
  • ESC and motors
VOXL 2 I/O (M0065) ✅ via MCBL-00061 UART cable
VOXL FPV ESC 4-in-1 (M0138) ✅ 5 V version powers VOXL 2 directly; kit ships with VOXL 2 cabling
VOXL Mini 4-in-1 ESC (M0129) ✅ use the 5 V version (M0129-5 / M0129-65)
Flight Core v2 (M0087) ✅ external flight controller mode
MIPI image sensor modules (M0161, M0166, M0173, M0178, M0186) ✅ up to 6 concurrent
M0189 8x8 ToF Module ✅ requires additional cabling
FLIR Boson ✅ USB and MIPI
FLIR Lepton ✅ USB and SPI
Wi-Fi / 4G LTE / 5G / Microhard modem add-ons ✅
VOXL Power Module v3 (M0041) ✅
M0188 / M0195 VOXL 2 Mini carrier boards ❌ VOXL 2 Mini only
For the full accessory matrix see the VOXL 2 Feature Matrix.
VOXL 2 Reference Drones
Starling 2 · Starling 2 Max
Radio Frequencies Used None on the board itself — RF is provided by optional add-on modems
Technical specifications
  • Autonomy
    • 36 x 70mm SWaP-optimized for GPS-denied Navigation, Obstacle Avoidance
    • Seven simultaneous MIPI inputs such as EO, Thermal, TOF, and CV cameras
    • Pre-integrated thermal camera support for FLIR Lepton® and Boson®
    • Open-source software: Open CV, ROS 2, Docker, PX4 and Ardupilot integrated flight controller
  • Artificial Intelligence
    • The QRB5165’s Qualcomm AI Engine pushes 15 TOPS of AI performance with industry leading power consumption
  • Connectivity
    • WiFi, 4G/5G, Doodle Labs, Microhard
VOXL 2 Development Kits
  • Starling 2 Max
    The Starling 2 Max isVOXL 2-powered, NDAA-compliant development drone supercharged by VOXL SDK specifically designed for outdoor, computer vision-based, long-range dead reckoning with a 500g payload capacity.
    From $2,999.99
    Learn More
Compare VOXL
ModalAI, Inc. Dev Kit VOXL<sup>&reg;</sup> 2 Mini
VOXL 2 Mini
CPU: QRB5165
OS: Debian Buster
GPU: Adreno 650 GPU - 1024 ALU
NPU: 15 TOPS
Built in Wifi: No
USB 3 Add-on Connectivity: WiFi, 5G, 4G/LTE, Microhard
MIPI-CSI2 Inputs: 4
Video Encoding: up to 8K30
Computer Vision Sensors: QTY 2 Stereo Pair, QTY 1 Tracking
Dimensions: 42mm x 42mm
Weight: 11g
VOXL SDK: Yes
ROS: ROS 2
NDAA Compliance: Assembled in USA, NDAA '20 Section 848, NDAA '21 Section 841
CPU: QRB5165
OS: Debian Buster
NPU: 15 TOPS
Built in Wifi: No
B2B Add-on Connectivity: WiFi, 5G, 4G/LTE, Microhard, Doodle Labs
MIPI-CSI2 Inputs: 6
Dimensions: 70mm x 36mm
Weight: 16g
VOXL SDK: Yes
ROS: ROS 2
