Weight is the dominant factor when designing a drone that can fight gravity in flight.
At 42mm x 42mm, VOXL 2 Mini is only 11 grams and is as small as an Oreo. Achieve the same performance as VOXL 2 but in a smaller form factor.
VOXL 2 Mini brings the full Blue UAS Framework autopilot stack to the smallest drones. Powered by the Qualcomm QRB5165, it combines a premium-tier companion computer and a flight controller into an 11-gram, 42 mm x 42 mm PCB stack with a 30.5 mm standard mounting pattern — small enough to make almost any airframe or ground robot an autonomous drone.
VOXL 2 Mini runs the same VOXL SDK as VOXL 2, so GPS-denied navigation, visual inertial odometry (VIO), SLAM, obstacle avoidance and on-board AI all carry over. It is NDAA '20 Section 848 compliant and assembled in the USA.
For how it compares with other options, see Top 5 Companion Computers for UAVs.
| Feature | Details |
| CPU | Qualcomm QRB5165 — 8 cores up to 3.091 GHz |
| Memory | 8 GB LPDDR5 / 128 GB Flash |
| GPU | Adreno 650, 1024 ALU |
| NPU | 15 TOPS — NPU and GPU-accelerated TensorFlow Lite |
| Operating System | Ubuntu 18.04, Linux kernel v4.19 |
| Flight Controller | Embedded — PX4 or ArduPilot on the sensors DSP |
| Integrated Sensors | 2x TDK ICM-42688-P IMU, 1x ICP-10100 barometer |
| Image Sensors | 4 concurrent MIPI |
| Video Encoding | 8K30 H.264 / H.265, 64 MP still images |
| Add-on Connectivity | Via USB3 port — Wi-Fi, 5G, 4G/LTE, Microhard |
| Thermal Cameras | FLIR Boson (USB), FLIR Lepton (USB; SPI in development) |
| Power Consumption | 0.5 - 8 W |
| Dimensions | 42 mm x 42 mm, 30.5 mm x 30.5 mm industry-standard mount |
| Weight | 11 g |
| Software Requirement | Platform Release 1.0 or newer |
| Compliance | NDAA '20 Section 848 compliant, assembled in the USA |
voxl-modem and the rest of the voxl-software packagePer our M0104 Product Change Notification, we have migrated from the original M0104 version of VOXL 2 Mini to the M0204 version.
| MPN | Description | Contents |
| MDK-M0204-1-00 | Board Only Kit | (1) VOXL 2 Mini board |
| MDK-M0204-1-01 | Dev Kit with APM, no image sensors | (1) VOXL 2 Mini board (1) Add-on power module Cabling |
| MDK-M0204-1-02 | Dev Kit with 4-in-1 Mini ESC, no image sensors | (1) VOXL 2 Mini board (1) VOXL Mini 4-in-1 ESC (3.8 V version) Cabling |
| VOXL Mini 4-in-1 ESC (M0129) | ✅ use the 3.8 V version (M0129-3 / M0129-63) — it powers VOXL 2 Mini directly |
| VOXL FPV ESC 4-in-1 (M0138) | ✅ high-current 5in, 7in and 10in FPV applications — 3.8 V variant powers VOXL 2 Mini directly |
| VOXL 2 I/O (M0065) | ✅ |
| M0188 / M0195 carrier boards | ✅ required for ToF and offboard sensor ports |
| M0189 8x8 ToF Module | ✅ requires M0188 or M0195 carrier and MCBL-00128 |
| MIPI image sensor modules | ✅ up to 4 concurrent |
| FLIR Boson / FLIR Lepton | ✅ USB (Lepton SPI in development) |
| Wi-Fi / 4G LTE / 5G / Microhard modem add-ons | ✅ via USB3 port |
| Flight Core v2 | ✅ external flight controller mode |
| VOXL 2 add-on boards (M0017, M0078, M0151) | ❌ VOXL 2 only — different form factor |
Note: order the M0138 variant that matches your power rail — the 3.8 V version powers VOXL 2 Mini directly, the 5.1 V version powers VOXL 2. The VOXL Mini 4-in-1 ESC is the lighter choice for vehicles under 750 g.
| Item | Value |
| ECCN | EAR99 |
| Country of Origin | USA |
| Radio Frequencies Used | None on the board itself — RF is provided by optional add-on modems |
| RoHS Compliant | Yes |
